*hf_DeleteSectionHandle
Delete a handle of a section.
*hf_DeleteSectionHandle handle_id
HyperMesh Tcl Modify Command
This command deletes a handle of a section. The section is automatically identified.
- handle_id
- The handle ID to delete.
To delete the handle with ID 12:
*hf_DeleteSectionHandle 12Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
