*hf_EditPol
Opens the Section Editor and loads the POL profile into the 2D editor.
*hf_EditPol reserved
HyperMesh Tcl Modify Command
This command opens the Section Editor and loads the POL profile into the 2D editor.
- reserved
- Reserved for future use. Must be set to 0.
To edit the POL profile:
*hf_EditPol 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
