*hf_SlideHandleptrOnSectionPlane
Updates the handle position. The binder and the section are automatically identified.
*hf_SlideHandleptrOnSectionPlane handle_id x_mouse y_mouse reserved
HyperMesh Tcl Modify Command
This command updates the position of handle with ID handle_id from its current position, to the new mouse position with coordinate (x_mouse and y_mouse).
- handle_id
- The ID of the handle to position.
- x_mouse
- Mouse x-coordinate of the new handle position.
- y_mouse
- Mouse y-coordinate of the new handle position.
- reserved
- Reserved for future use. Must be 1.0.
To update the position of the handle with ID
5:
*hf_SlideHandleptrOnSectionPlane 5 1982.39933 287.781925 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
