*hf_TrimBinderOrAddendumWithAddDbeadDbar
Trims the current die module binder or addendum with the current addendum drawbar/bead FL.
*hf_TrimBinderOrAddendumWithAddDbeadDbar entity_type_surf mark_id_surf entity_type_line mark_id_line
HyperMesh Tcl Modify Command
If an input is not specified, the binder and FL are recognized automatically and trims the current die module binder with the current addendum FL. If the surface mark is empty, it trims the current die module binder with the line contained into the line mark (trim binder with drawbar/bead).
If the surface mark is full, it trims the addendum surface contained in the mark with the line contained into the line mark (trim addendum with drawbar).
- entity_type_surf
- Must be set to surfs
- mark_id_surf
- The mark ID containing the surfaces. Valid values are 1 and 2.
- entity_type_line
- Must be set to lines.
- mark_id_line
- The mark ID containing the lines. Valid values are 1 and 2.
*createmark lines 1
*createmark surfaces 1
*hf_TrimBinderOrAddendumWithAddDbeadDbar surfaces 1 lines 1*createmark lines 1 11
*createmark surfaces 1 33
# Handle error
}Version History
11.0
